slips out of 3rd gear
wilburn
09-29-2003 10:51:49
i have a 39 ac-b that i am trying to get all the bugs out of. when you put it in 3rd gear it slips out.you can apply just a little bit of pressure on the gear stick and it will stay in,but when you remove your hand it will slip out.can someone tell me what to check and or how to fix it? thanks
Wd Tom
09-29-2003 18:20:13
 Re: slips out of 3rd gear in reply to wilburn, 09-29-2003 10:51:49
I believe for third in a B a gear slidesforward and engages with the imput shaft so the power flows straight through the transmission notusing any of the gears for gear reduction. The dogs on the engaging surfaces of the gears become worn from grinding into gear and after many years of this can wear enough to let it slip out of gear. Had the same thing. New gears were like $250 ea. some years ago. Ended up buying the whole back half of a C with foot brakes and wheels (not rims) for , if I remember, $275. Got a better and newer tractor out of it. I still have the B rear end and it is one of my distant projects to take it apart and see if I could mill the surfaces that are worn to new shape. It would have more backlash but probably not enough to be noticable. Never heard of this being done, maybe it can't, but I wanted to look and see.
