Help with serial # on wd 45
Jack B
09-28-2003 15:21:39
The serial # on my tractor is wd42788 not sure about year model could any one help with this. It does"t seem to be the same as year models on this web site.I might not be reading it right.I had another guy check it he came up with the same number.
ACEd
09-30-2003 21:47:17
 Re: Help with serial # on wd 45 in reply to Jack B, 09-28-2003 15:21:39
Tractor serial number and motor serial number on left side of block behind carb tell the story. Possible a digit is not readable, I've seen such, but it would have to be a missing 1 at front i.e. WD142778, but that would still be a WD. If shifter is straight and motor has the plate on right side as mentioned elsewhere, its a WD. As an aside, I was told by a guy in Ms some time back, that less scrupulous used tractor salesmen would sometimes repaint WD's and decal them as 45's to get more $ for them - supposedly some even went to trouble to grind off s/n off rear in some extreme cases. Caveat Emptor.
Matt
09-28-2003 19:32:30
I am new to this discussion forum but I got my Allis-Chalmers book out and according to the #'s you posted I came up with a 1950 WD also. The book says the serial # is on the top left differential brake housing. Is it possible that the differentail housing was changed, or the sheet metal was changed.
steve
09-28-2003 15:49:38
how about a 1950 WD, not a 45
Jack B
09-28-2003 17:58:09
 Re: Re: Help with serial # on wd 45 in reply to steve, 09-28-2003 15:49:38
Steve it might be but the Numbers on both sides say wd 45 looks like oringinal stickers. Thanks Jack b.
JMS/MN
09-29-2003 09:10:47
 Re: Re: Re: Help with serial # on wd 45 in reply to Jack B , 09-28-2003 17:58:09
Stickers don't mean squat- engines are more difficult to change. WD engine has a removeable panel on the right side, WD45 engine has a solid cast right side. Differential serial number tells the whole story.
steve
09-28-2003 18:19:54
read the note from wdTom, two posts below yours
