Allis Chalmers 190XT
Rick MN
09-25-2003 05:34:20
Well fellas,
I bought me a AC190XT last night, cab, loader, and a set of chains for $1500.00. It has a weak clutch and needs some injector work, a few leaks also. The owners are honest and told me it has some problems, but I figure as good as it started and sounds (like I said it smokes some)I can afford to put some money in it if need be. It is a little big for moving snow and just working around the place but may be nice if we get heavy snow this winter (my prediction).
I am looking for an outlet to buy used parts. Fenders and othe sheet metal are rough. It would be nice to get it cleaned up and all the leaks stopped. If you have any tips and pointers I would appreciate the help.
Thanks for your previous help!
N. Webb
09-29-2003 19:30:38
 Re: Allis Chalmers 190XT in reply to Rick MN, 09-25-2003 05:34:20
Here are acouple of places you can try the first is Central Tractor(270)242-4591 the next is Mitchell & sons (270)754-1723
N Webb
09-27-2003 18:02:50
I know a place in Kentucky where you can get parts for the 190 it is located in Big Cliffy Kentucky and it is the only tractor parts in that town.
Rick MN
09-29-2003 13:19:32
 Re: Re: Allis Chalmers 190XT in reply to N Webb, 09-27-2003 18:02:50
What is the name or phone number?
nwebb
09-27-2003 17:58:21
I have a 190xt and I love it. This is only the second tractor I have ever been on and like I said I love it. Did you say yoou have a front loader on it ? If so would you like to sell it?
Rick MN
09-29-2003 13:21:42
 Re: Re: Allis Chalmers 190XT in reply to nwebb, 09-27-2003 17:58:21
Yes it has a loader, but I will keep that on there. Should come in mighty handy this winter. I would be interested in finding some new sheet metal, and fenders.
EIL
09-25-2003 20:25:25
Hello. I am currently going to a local vo-tech school hear in southern louisiana and a good buddy of mine had just split a 190xt propane. A guy which used to work at a local allis-chalmer dealership years ago said that this model mas to be split every 5 years to change a seal which is exactly what we did. It is the seal between the transmission and the hydrolic reservoir. This tractor used to have a VERY bad leak. It would pretty much drain the transmission of fluid. His lean would come out the shifter above the transmission and at the 3-point hitch. If this is one of your leaks then would have a big job ahead. He spent over $300 on the parts plus the gasket is hard to find. Other than that they had zero problems with this tractor.
