how do I get the manifold off my wd 45?
dave
09-24-2003 18:32:36
Any recommedation on the best approach to loosening the nuts so I can remove the manifold?They seem to be rusted on and I am afraid I will twist the studs off. Then what would I do??
Appreciate it if you would share your secrets!!
thanks Dave
CHALMERSBOB
09-25-2003 19:23:59
 Re: how do I get the manifold off my wd 45? in reply to dave, 09-24-2003 18:32:36
USE BRASS NUTS ON THE STEEL STUDS. THIS WILL MAKE REMOVAL EASIER NEXT TIME LOL BOB
wdTom
09-25-2003 17:31:42
Similar to John's idea,but a little gentler, cut the nut with a Dremal tool or other such, on one side. That is cut about one third of it off, cutting downbeside the stud. I put stainless studs and nuts back on mine. Made the studs from rod and bolts I had around, cutting threads on my lathe.
Bob D. (La)
09-25-2003 03:12:12
I have recently removed manifolds from a WC, an Allis C and CA. All three of these tractors had nuts that looked so rusted they were frightening. I used a product called Kroil which can only be purchased from Kano labs. Sprayed it on, waited a few minutes and started removing them,using a little more Kroil as needed. Didn't twist off nor harm any of the studs or nuts. HTH
CWL
09-25-2003 09:32:24
 Re: Re: how do I get the manifold off my wd 45? in reply to Bob D. (La), 09-25-2003 03:12:12
Kroil is great stuff! It's a little costly, but well worth it.
DanD.
09-24-2003 20:28:34
Heat the nuts with a torch until they're red hot and they will turn right off.
John Rogers
09-24-2003 19:20:07
Hi, I usually have someone hold a heavy backing bar again one side of the nut and drive a sharp chisel into the opposite side to split the nut. A air hammer works great if you have one. Good luck, John in MO
