Oversize pistons
Jan Ferreira
09-22-2003 07:40:29
I would like to know if there are oversize pistons & rings available for an Allis Chalmers B 3 5/8 bore. If so where can I order them from (I live in South Africa). If they are not available, are there any other pistons that I can use and what are the specs, eg compression height, gudgeon pin diameter, piston length, etc? If any body can help it would be greatly appreciated as my pistons (cast iron) was stolen.
Eddie
09-22-2003 11:48:43
 Re: Oversize pistons in reply to Jan Ferreira, 09-22-2003 07:40:29
You might look into using D15 piston & sleeves, its the same family of motors (149 cu.).
Dick L
09-22-2003 10:05:12
I think you mean 3 3/8" pistons, and the quick answer is no. You could buy a set of 3 7/16 rings and file the ends to fit the cylinder walls. With your pistons gone, if it were me, and I know it aint, I would buy an engine rebuild kit with piston, sleeves, rings, pins, bearings, and gaskets.
Jan F
09-22-2003 22:55:37
 Re: Re: Oversize pistons in reply to Dick L, 09-22-2003 10:05:12
Yes sorry it should be 3 3/8. I would buy a kit if I could find somebody that will sell me one and ship it to South Africa. Meanwile I'm looking at all possibilities.
Dick L
09-23-2003 06:14:24
 Re: Re: Re: Oversize pistons in reply to Jan F, 09-22-2003 22:55:37
You should have an improter that carries tractor repair parts. I have had several emails that wanted me to import parts from your part of the world. Deleted them as that is not my game but some machinery dealer should have contacts to get them for you.
