Pulley size for Allis B
Wayne
09-21-2003 20:15:10
My dad needs to know what the pulley diameter is (the one on the PTO shaft) that is on the Allis B's to run equipment such as the belly sicklebar mowers. In the event we don't locate one we are thinking of putting one together.
Rod (NH)
09-21-2003 20:45:21
 Re: Pulley size for Allis B in reply to Wayne, 09-21-2003 20:15:10
Hi Wayne,
The PTO drive pulley for my '42 B belly sickle mower is 10" OD. I use a Gates #C51 belt.
third party image Rod
Wayne
09-22-2003 18:38:26
 Re: Re: Pulley size for Allis B in reply to Rod (NH), 09-21-2003 20:45:21
Thanks...Some people say that mowing in first gear is fine but in 2nd is too fast. We thought about upping the pulley diameter a bit to get a litle more speed out of the mower, but if we do so I think we would be asking for alot of pitman stick beakages. We have never used an Allis B with a mower like this. I have a larger tractor with a 501 Ford mower and if I run it rather fast there goes the pitman sticks. Any ideas?
Rod (NH)
09-23-2003 05:27:24
 Re: Re: Re: Pulley size for Allis B in reply to Wayne, 09-22-2003 18:38:26
Wayne,
I always mow in first gear at about half throttle. The manual states to use second gear and 1/2 - 3/4 throttle for "average" mowing conditions and first gear at 1/2 - 3/4 throttle for "heavy" mowing conditions. I find second is always too fast for me. It also increases the possibility of significant damage by hitting a forgotton rock with the cutter bar...this is new england after all :o). Both the original drive and driven pulleys are really two part pulleys. There are shim stock spacers between the two halves of each pulley. You can add or remove spacers to vary the pitch diameters (within limits) and increase or decrease the sickle strokes per minute for any particular throttle condition. The manual states that the sickle strokes per minute is 715 as the drive pulley is assembled from the factory. This is with the pto at 560 rpm, which is at full engine throttle.
I have never played around with changing the shims. The manual indicates increasing the sickle speed only for "adverse" mowing conditions. Mine has worked well for years as is so I have no particular reason to mess with 'em. The outside surface of the C section belt is flush with the 10" OD of the drive pulley, so the pitch diameter is less than 10" the way mine has always been set.
I don't think it would be a good idea to go bigger on the drive pulley. To be honest, I don't see a reason to. As far as pitman rods go, the two I have broken in recent years have been caused by me carelessly backing them onto a stump or a rock. I make my own out of hard maple and always keep a spare made up on hand just in case.
