Stuck Thermostat or Stuck Temp. Gauge?
Trent
09-20-2003 19:02:53
My D14 temp gauge did not move off 130 deg. today when I mowed (normally stays at 170-180). I guess either the gauge stuck or the thermostat is stuck open. What is the best way to find out for sure? Both have less than 40 Hrs. on them. One thing I did try was tried covering the grill with plastic and let her run for awile to see which would happen first.. the gauge come up, or get hot. Got tired of waiting, with the air temp. cooler, and no load looked like it was not going to do anything.
Jim E
09-21-2003 07:02:20
 Re: Stuck Thermostat or Stuck Temp. Gauge? in reply to Trent, 09-20-2003 19:02:53
Is radiator fluid touching the thermostat? Might be low.
wdTom
09-20-2003 19:48:06
Try putting a meat thermometer in the top of the radiator. Be carefull removing the cap to do it if the engine is hot.
