more rpm from allis model c
peter
09-18-2003 18:36:12
what can i do to get 500 more rpm without rebuilding motor thanks in advance
Dick L
09-19-2003 08:12:30
 Re: more rpm from allis model c in reply to peter, 09-18-2003 18:36:12
easy way is to put a stronger spring where the throttle linkage connects to the governor.
If you want this for speed it will help, if you want it for pulling contests it will not help without adding HP. As soon as you put a load on the engine you will lose the rpm's. If you increase the HP the added RPM's helps a bunch, if they allow it.
