ca allis
dick
09-17-2003 21:12:01
I have a ca that is slipping the hand clutch what is the procedare to adjust clutch. There is no free travel.
DanD.
09-18-2003 10:33:16
 Re: ca allis in reply to dick, 09-17-2003 21:12:01
Look down in the hole where the handle goes. You'll see a set screw (a small bolt) that you need to loosen. Now, find the thing that looks like a small gear (there are teeth on it for prying against it with a screwdriver). THen, take a large screwdriver and turn this "gear" until there is a small amount of space between the throwout bearing and the clutch. Retighten the set screw and you're set.
dick
09-18-2003 21:12:55
 Re: Re: ca allis in reply to DanD., 09-18-2003 10:33:16
sounds good i will try this tomarrow
