D-17 Diesel conversion
Terrance
04-07-1999 09:21:39
I have a D-17 diesel with a cracked head. I also have an engine off of a C combine. It is the AC 262 6 cylinder gas engine. It is the cubic inch displacement as the diesel. Does anybody know if this engine will fit into the D-17? Will the frame and engine fit together and how much will I have to rig together? I don't plan on using the tractor much it's just a side project. Is this worthwhile or would it be better just to find a new head for the diesel. Any help would be greatly apprecitated.
Joe
04-25-1999 07:28:10
 Re: D-17 Diesel conversion in reply to Terrance, 04-07-1999 09:21:39
My neighbor replaced the gas engin in a D-17 with one off of a Gleaner E. They were exactly the same except for a port that he had to put a plate over.
jon
04-07-1999 15:29:16
hello I have seen it done, BUT it was a WD-45 desiel with a 6cyclinder gas combine engine. Im sorry that I cant tell you the specifics. I seen it a local tractor pull.
jbaker
04-12-1999 09:27:42
 Re: Re: D-17 Diesel conversion in reply to jon, 04-07-1999 15:29:16
the combine engine wil need some tractor componnents to work in tractor,use the stuff from d-19 gas to make it work
