1954 WD-45 Engine
David Starkjoha
09-16-2003 11:21:12
I bought a 1954 WD-45 the unit is in restored condition with one exception. The previous owner must have been hard of hearing, since she knocked a rod loose. I am looking for a WD-45 block and a crankshaft or a short block.
Thanks for your help.
wdTom
09-16-2003 17:51:13
 Re: 1954 WD-45 Engine in reply to David Starkjohann, 09-16-2003 11:21:12
Why don't you see if the crank is out of round, maybe just bearings. Or grind the crank and put in all new bearings. If the rest of the engine seems to be good.
David Starkjohann
09-17-2003 09:52:35
 Re: Re: 1954 WD-45 Engine in reply to wdTom, 09-16-2003 17:51:13
I mentioned that the previous owner was a little hard of hearing to the point the rod let go and out the side of the block she went. The crankshaft has sufficient damage that it would have to be welded then reground to make it usable.
Past experience with crankshaft welding has not been good so I am reluctant to go that route. The block as a last resort could be welded and that is my fall back plan if all else fails.
I figured I would eliminate all other options first.
Thanks for your input wdTom have a nice day.
wdTom
09-18-2003 18:35:30
 Re: Re: Re: 1954 WD-45 Engine in reply to David Starkjohann, 09-17-2003 09:52:35
Well now I get it, didn't quite understand you had a hole in the side of the engine and other problems.
