1952 Allis Chalmers B steering box bearing
Tracy White
09-13-2003 18:03:24
Need bearings for 1952 model B steering box. New or used. Can't find them! Can anybody help me?
Tony
09-14-2003 20:04:50
 Re: 1952 Allis Chalmers B steering box bearing in reply to Tracy White, 09-13-2003 18:03:24
I got bearings for my 48 C through my local Agco Allis dealer you may try there
jerry
09-14-2003 05:10:52
check the ball bearings in a Briggs @ Stratton 8 hp engine recoil starter.
Tracy White
09-14-2003 07:49:43
 Re: Re: 1952 Allis Chalmers B steering box bearing in reply to jerry, 09-14-2003 05:10:52
Is that the balls only? The cage from mine is also damaged. Anyone ever tried reassembling without the cage? In this situation I think it might be O.K. Anyone agree or disagree?
wdTom
09-15-2003 16:53:00
 Re: Re: Re: 1952 Allis Chalmers B steering box bea in reply to Tracy White, 09-14-2003 07:49:43
Loose ball bearings are ok in low speed applications. Just stick them in with grease and put it together. You should be able to get loose ball bearings from a bearing supply.
