WD-45
Joe
09-13-2003 17:44:29
I just bought my wifes grandfathers WD-45 on a sale. Needs plugs but ohterwise seems okay. Does anyone know what brand of live hyd pump they used? It looks like a Char-lynn like on a M Farmall.Seems to leak in between the pump and the engine. Also where can you get new knobs for the shift lever and pto? This is my first Allis, I have mostly Case but I'm growing tired of not being able to find parts. Also how rare is factory power steering? The tractor is a 54 if I read the sn# right.
Smitty
09-14-2003 11:48:33
 Re: WD-45 in reply to Joe, 09-13-2003 17:44:29
Power Steering didn't arrive on the WD45 until '56; however, there were several aftermarket systems available, including one made by Char-Lynn.
The hydraulic pump was their own, and is "live" only in the sense that the pump is driven ahead of the transmission clutch. The foot clutch still renders the pump inoperable.
Joe
09-14-2003 16:44:57
 Re: Re: WD-45 in reply to Smitty, 09-14-2003 11:48:33
When I talk of a live pump, it is just like the Char lynn on a M and is in between the engine and distributer. The sn# is 177688 and the power steering is factory and listed on the bill of sale.
Smitty
09-15-2003 05:43:41
 Re: Re: Re: WD-45 in reply to Joe, 09-14-2003 16:44:57
You're right, a pump mounted as you describe would make it live, but I don't think it is factory A/C. I'm refering to Norm Swinfords authoritative book on A/C when I state that it wasn't factory available until '56. I've seen at least 4 different styles of Power Steering installed on WD's, and so there were many aftermarket systems avail.
Is it possible that yours was an aftermarket system installed by the dealer prior to innitial delivery? Regardless, enjoy your new toy, as they are great tractors.
Also, you are correct in that your ser # indicates your unit to be a mid '54 model.
Good Day!
Scott A, MO
09-13-2003 17:55:56
All the gaskets, and o-rings are available from your local AGCO Dealer. I just bought all new o-rings and gaskets yesterday for my 49-WD, and have the pump and valve body apart on the bench as I write this. They did have to order a few parts. It's not a very hard job. Comes appart fairly easily, just make shure and remember which way you take it apart, so you can reassemble it later. If you need a photo of the break down on the pump assy. e-mail me.
