D19 question
Buck
09-13-2003 16:20:27
Just curious as to how much gas can be run through the D19 in an hour, baling, cutting, disking, plowing etc. Also how big is the gas tank on the 19?? Thanks for the info.
Eldon
09-14-2003 10:18:48
 Re: D19 question in reply to Buck, 09-13-2003 16:20:27
According to the Nebraska tractor test, the D19 produced 11.48 hp hours per gallon of gas. If you take the 71.54 available pto hp and divide this by 11.48 you would get the maximum gallons per hour (6.23). Actuallly the turbo diesel wasn't much better at 11.54 hp hrs per gallon of diesel, but since it only produces 62.05 max hp it appears more economical.
stephen
09-13-2003 21:31:19
I hate to say it, but your fuel tank is only 23
gallons. As far as fuel economy goes, the only
experience I have with the 262AC engine is in
a 802 cotton picker. It took about 2 gallons of gas for a 20 minute drive to my house. I have a
D19 but it's a turbodiesel.
david l wilson
09-14-2003 06:19:47
 Re: Re: D19 question in reply to stephen, 09-13-2003 21:31:19
to give you an idea this year i mowed and raked 22 acres of hay with my d17d and 9' haybine on 15 gal of fuel then bailed the same with my d19g and heston big bailer and used about 35 gal of fuel for55 bailes of hay
Wally G
09-14-2003 07:13:45
 Re: Re: Re: D19 question in reply to david l wilson, 09-14-2003 06:19:47
Yeh the D19 sure likes it's gas-uses about 6 to 7 gallons an hour under medium to heavy work.
