Emergency
Garry Lees
04-20-1998 18:00:53
Help, I broke the nose piece off the starter on my HD 3! Has a Delco Remy # 1107502. The a/c part
#is 233562. Seems hard to find localy and possably nationaly.
Any ideas or sources appreciated.
E mail or Phone 970 945 6578. leave a message please and I will call back!
Thanks, Garry
Dave Richards
04-21-1998 05:23:57
 Re: Emergency in reply to Garry Lees, 04-20-1998 18:00:53
: Help,
: I broke the nose piece off the starter on my : HD 3! Has a Delco Remy # 1107502. The a/c part
: #is 233562. Seems hard to find localy and possably nationaly.
: Any ideas or sources appreciated.
: E mail or Phone 970 945 6578. leave a message please and I will call back!
: Thanks, Garry
Garry, That is the same starter that is used on the D-15 Diesel. Central tractor lists it in their current Catalog. Its around $240 exchange or $299 outright. If you check with a good starter rebuild shop, they can cross reference the starter better and maybe find a truck starter with the same housing. Or better yet, they may find a newer starter that will fit fust fine. The trick is to find a good rebuild shop that has all of the cross reference books.
Good Luck,
Dave
Dave Richards
04-21-1998 05:28:24
 Re: Re: Emergency in reply to Dave Richards, 04-21-1998 05:23:57
: : Help,
: : I broke the nose piece off the starter on my : : HD 3! Has a Delco Remy # 1107502. The a/c part
: : #is 233562. Seems hard to find localy and possably nationaly.
: : Any ideas or sources appreciated.
: : E mail or Phone 970 945 6578. leave a message please and I will call back!
: : Thanks, Garry
: Garry, That is the same starter that is used on the D-15 Diesel. Central tractor lists it in their current Catalog. Its around $240 exchange or $299 outright. If you check with a good starter rebuild shop, they can cross reference the starter better and maybe find a truck starter with the same housing. Or better yet, they may find a newer starter that will fit fust fine. The trick is to find a good rebuild shop that has all of the cross reference books.
: Good Luck,
: Dave
Garry, Central Tractor's # is 1 888 828-3276
to Dave
04-21-1998 06:33:40
 Re: Re: Re: Emergency in reply to Dave Richards, 04-21-1998 05:28:24
: : : Help,
: : : I broke the nose piece off the starter on my : : : HD 3! Has a Delco Remy # 1107502. The a/c part
: : : #is 233562. Seems hard to find localy and possably nationaly.
: : : Any ideas or sources appreciated.
: : : E mail or Phone 970 945 6578. leave a message please and I will call back!
: : : Thanks, Garry
: : Garry, That is the same starter that is used on the D-15 Diesel. Central tractor lists it in their current Catalog. Its around $240 exchange or $299 outright. If you check with a good starter rebuild shop, they can cross reference the starter better and maybe find a truck starter with the same housing. Or better yet, they may find a newer starter that will fit fust fine. The trick is to find a good rebuild shop that has all of the cross reference books.
: : Good Luck,
: : Dave
: Garry, Central Tractor's # is 1 888 828-3276
Thanks very much for the help Dave! I will call central tractor A.S.A.P.
Garry.
