Tractomotive Loader
Carroll Porter
04-06-1999 18:49:08
Anybody else out there with a loader needing chat time? I have a model T.L.W. , and am trying to find out if there are any other wheel tractor models with drive line parts compatable to my WF, serial no. WF 4716. Any help appreciated. Thank You Carroll Porter
Ron
04-07-1999 18:51:02
 Re: Tractomotive Loader in reply to Carroll Porter, 04-06-1999 18:49:08
Perhaps you could elaborate a bit on what you are looking for exactly?
Carroll Porter
04-08-1999 13:29:07
 Re: Re: Tractomotive Loader in reply to Ron, 04-07-1999 18:51:02
My Tractomotive loader was built on a WF model A/C farm tractor running gear. Having been in service from the mid 40's until the early 90's the final drive is pretty well worn. One brake band is broken,one pinion & bull gear a little torn up,gear mount casting broken into 4 pieces,large piece broken out of 1 of the outer axle bearing mounting flange,transmission has taken on water in the past,frozen up,and now has a cracked case,the gears aren't too good either. So far I have not had any luck finding anyone who is familiar with the WF model. I've located a trans & a final drive in Oregon{I am in vermont}, out of a WC, but I have no idea if they are interchangable. Thank you for the reply. C.P.
james randall
04-02-2000 22:55:58
 Re: Re: Re: Tractomotive Loader in reply to Carroll Porter, 04-08-1999 13:29:07
dear sir. could you please give me the model and ser.#,of your tractomotive loader. thank you j randall.i may be able to help you. send by e-mail
Carroll Porter
10-14-2002 20:05:36
 Re: Re: Re: Re: Tractomotive Loader in reply to james randall, 04-02-2000 22:55:58
My apologies, I must have missed your post. At the time that I was searching for tech info, I was at my wits end, had lots of inquiries out, but to no avail. I have since got it so I can use it. I have learned a lot about it in the last couple years.
It is a model TLW, serial # 4.
Email me if you want to discuss anything, maybe even give up some advice.
Thanks,
Carroll Porter
