Did the AC G ever have a PTO?
ShepFL
09-10-2003 19:20:22
Spoke with a fella tonite and he said his had one. I am curious what you would use PTO for on a G.
Also, thanks to all for the previous help on my D10. I have welded the manifold up and all appears to be ok until it decides to break somewhere else.
ShepFL
cecil pittman
09-14-2003 12:03:51
 Re: Did the AC G ever have a PTO? in reply to ShepFL, 09-10-2003 19:20:22
the ac g had NO pto
Eldon (WA)
09-10-2003 20:04:33
None listed as an option in the book.....maybe he meant a belt pulley. Some old timers called them a power take off. It could be a custom made job coming off the engine crank, but there isn't much room back there unless the standard drawbar was extended.
ShepFL
09-10-2003 20:19:29
 Re: Re: Did the AC G ever have a PTO? in reply to Eldon (WA), 09-10-2003 20:04:33
Thanks Eldon -
Been combing the web all nite trying to find a pic of one with a PTO. I did see several with belt pulley. Need to call this fella back tomorrow to discuss.
Again THANKS!!
Ronnie in TX.
09-10-2003 22:35:10
 Re: Re: Re: Did the AC G ever have a PTO? in reply to ShepFL, 09-10-2003 20:19:29
Belt pulley P.T.O.
geg-mo
09-11-2003 16:53:21
 Re: Re: Re: Re: Did the AC G ever have a PTO? in reply to Ronnie in TX., 09-10-2003 22:35:10
The pully is used with sickle bar mower and belly mount finish mower. They are hard to come by.
Brian G. NY
09-11-2003 17:33:07
 Re: Re: Re: Re: Re: Did the AC G ever have a PTO? in reply to geg-mo, 09-11-2003 16:53:21
Yep, The sickle mower is supplied with a v-belt pulley (sheave) to replace the flat belt pulley for providing power to the mower.
Bob Semrau
09-12-2003 10:06:55
 Re: Re: Re: Re: Re: Re: Did the AC G ever have a P in reply to Brian G. NY, 09-11-2003 17:33:07
One other note - I have both the Woods 42G belly mower and the AC sickle bar mower for my G, and they use different sheaves - if I remember right, the sickle is a 5" diameter, while the Woods is 7".
