1949 AC-C Engine has no Serial #, Help Identify
WU
09-09-2003 21:21:38
Need help identifing the engine on the subject tractor.
Engine Block Casting # is: AM2916 20
wu
09-10-2003 19:57:22
 Re: 1949 AC-C Engine has no Serial #, Help Identif in reply to WU, 09-09-2003 21:21:38
My casting # is AM2916-20.
So the casting year should have been 1948.
How do you determine if it's high or low compression? I guess I could measure volumes and divide. Is there any easier tell-tale sign. The motor is stuck so I can't measure compression.
ACEd
09-20-2003 10:17:43
 Re: Re: 1949 AC-C Engine has no Serial #, Help Ide in reply to wu, 09-10-2003 19:57:22
Compression Ratio is determined by the pistons - so if its stuck and you are going to replace pistons and liners, you can build it however you want subject to piston availability - which probably means standard gas late pistons at 5.7:1.
As to motor s/n, its actually on the edge of the flange where motor mounts to transmission at about a 45 degree angle. Probably have to scrape paint off.
steve
09-11-2003 15:15:52
I would always assume i had the standard (high) unless you have a special intake manifold, warm up fuel tank under the hood, or special serial number on the block. i know of no other way except pull the head and start measuring.
steve
09-10-2003 19:45:00
all CE motors have the casing number AM2916. I believe Dick L did a study and believes the last two numbers designate the year of manufacture. Started in 1938 with 10, 1939 ws 11, 1940 was 13, etc. so 20 would be 1948. I tries this on my 3 B tractors and believe Dick is correct, it works. my 29 was built in 1957.
Thomas T. in S.C.
09-10-2003 15:41:41
C On my 1948 C, the serial numbers are on left side, if you are on the sitting on it, behind the oil bath air cleaner, on the 45 degree flat spot on the back of the engine, the serial number on my 48 C is CE118352-G.
wu
09-10-2003 18:59:52
 Re: Re: 1949 AC-C Engine has no Serial #, Help Ide in reply to Thomas T. in S.C., 09-10-2003 15:41:41
Hello Thomas T.:
Already checked the left side and rear of the block. No serial # found. The casting number on the right side of the block is AM2916 20. What's your casting #?
WU
wu
09-10-2003 18:52:13
Hello Thomas T.:
WU
Thomas in S.C.
09-10-2003 19:41:59
 Re: Re: Re: 1949 AC-C Engine has no Serial #, Help in reply to wu, 09-10-2003 18:52:13
Sorry, was out pullen post up, the casting # in the center right side is, AM 2976 25.
wu
09-10-2003 19:46:58
 Re: Re: Re: Re: 1949 AC-C Engine has no Serial #, in reply to Thomas in S.C., 09-10-2003 19:41:59
Here's some info on dating the casting:
http://www.ytmag.com/ac/messages/29748.html
Thomas in S.C.
09-10-2003 20:11:42
 Re: Re: Re: Re: Re: 1949 AC-C Engine has no Serial in reply to wu, 09-10-2003 19:46:58
Oh, ok, maybe the 1 just looks like a 7, so that would make my casting number, AM 2916 25, but it is a 1948 !
