someone who knows WC rims
rhudson
09-09-2003 19:47:33
There's got to be someone out there that knows where to find 12 x 28 inch rear rim with 6 humps to fit a wc. i can only find 10 inch width. my old wc has 12 inch width with one in bad shape. Thanks for any help.
mark
09-14-2003 18:47:00
 Re: someone who knows WC rims in reply to rhudson, 09-09-2003 19:47:33
i have two wheels 28 for a wc need 400.00 for the pair in nice shape just put tires on and go well needs paint give me a call at 785 528 3001 and we can talk . have a nice day mark
steve
09-10-2003 16:11:23
try www.millertire.com
rhud
09-10-2003 17:19:07
 Re: Re: someone who knows WC rims in reply to steve, 09-10-2003 16:11:23
10 inch is the widest 6 hump they carry, but Thanks
steve
09-10-2003 19:51:52
 Re: Re: Re: someone who knows WC rims in reply to rhud, 09-10-2003 17:19:07
they list it in the home page, but maybe they dont have them?? they might be able to steer you in the right direction if they dont have them.--this is a cut and past from miller---
Bolt Circle is measured from center to center of two bolt holes directly opposite of each other.
SIZES BOLT
CIRCLE PRICE 7x24 with 4 clamps 20 1/2 $60.00 8x24 with 4 clamps 19 3/4 69.00 9x24 with 4 clamps 19 3/4 73.00 10x24 with 4 clamps 19 3/4 74.00 12x24 with 6 clamps 20 1/4 92.00 9X28 with 6 clamps 24 1/4 79.00 10X28 with 6 clamps 24 1/4 80.00 11X28 with 6 clamps 24 1/4 83.00 12X28 with 6 clamps 24 1/4 92.00
Brad Gyde
09-14-2003 08:18:51
 Re: Re: Re: Re: someone who knows WC rims in reply to steve, 09-10-2003 19:51:52
I just got a set of the mentioned rims (used) off of a tractor a friend picked up at a auction. I'm not wanting to sell them though. I just have a few ideas I had previously looked into....
Ford "N" series rims will bolt to the centers, as 1 of the 4 rims that came with mine was a original ford rim (and it was on a center)
you could also patch your rim, depending on how bad it is. Mine had a hole 2-3" wide and about 12" long near the valve stem hole. I took a piece of sheet metal, heated and pounded it the best I could and used sheet metal screws to fasten it. I then welded it in places. My intent was to weld it al the was around, then remove the screws and use body filler to fill in the area and make it look like new. (I'm not sure how wide this rim was, but if it is a 12", I'd concider getting rid of it if you are interested in it)
I have also saw done where you can cut out sections of 2 or 3 bad rims and make a good one, but I am not that skilled of a welder.
rhud
09-11-2003 06:15:33
Hi Steve,
my wc uses wedge blocks that seat against 6 humps or bumps on the rim, not the loops like in your cut and paste. my bolt center is 24 3/4 inches so i don't think i could even get with the loop rim. if both rims were bad, i'd just make some centers out of 1/4 or so and bolt them to the 6 loop rims that you have shown. but with one good rim, well darn if you do and will not roll if you don't.
Thanks for the effort. i just keep thinking there's got to be a 12", 6 hump rim out there somewhere or someone thats solved this problem
