Unknown AC in the weeds
Lee
09-09-2003 16:56:33
What is this thing? Unfortunately I don't have a way to post the picture here, but it looks like a WD but it has hand brakes and 11-28 tires on it. It's not a C. It's bigger looking than that. It has styled sheet metal and the front of the frame extends about a foot beyond the grille. There are what look like two brake drums on either side of the gas tank, out towards the wheels. It has lights like on a WD. I didn't have a chance to look for serial numbers or anything, and am confused by the braking setup. I've driven a B with hand brakes before, but this is nothing like that. Please offer suggestions. I can email pictures to individuals. Email me at [email protected]
Emmet
09-12-2003 23:43:46
 Re: Unknown AC in the weeds in reply to Lee, 09-09-2003 16:56:33
Hi
What looks like 2 blowers could be the mechanical lift system. One "blower" is located below the gas tank on the right side above the frame and on the outer side of the frame and the other in the center located directly under the gas tank and follows after the transmission. The lift system is activated with a foot pedal located on the right side of the steering wheel.
Emmet
Lee
09-11-2003 10:26:12
Thanks for all the help. I went back out there today and found the serial number. It is indeed a WC, SN 85069, so that makes it a 1939. According to the guy that showed me the tractor, the blowers are indeed from a corn picker. Any idea what would be a fair price for a parts tractor like this? I think there is only one good rim on the back, and the engine may be stuck. -not sure on that. Unless it's one of the very first styled WC's, I'm thinking that it's just a parts tractor, and too far gone to restore. Ideas?
Trevor
09-10-2003 08:22:02
Lee, are you sure it isn't an RC?
They looked like the WD & WC but had the small B,C,CA engine. The frame was WD or WC but is stuck out past the engine alot more than a WC or WD. Look for pictures and make sure.
RCs are kinda rare so it is worth looking into.
wdTom
09-09-2003 18:04:11
Must be a styled WC.
Lee
09-09-2003 18:50:03
 Re: Re: Unknown AC in the weeds in reply to wdTom, 09-09-2003 18:04:11
Thanks for the info. I looked at some more WC Pictures and that looks right. However, it looks like there are two squirrel cage blowers mounted on either side of the gas tank that would blow towards the rear of the tractor. Any idea what those would be? At first I thought they were part of the brakes, but none of the other WC's I've looked at have them, so it must be some sort of attachmet? Please help if you can! Thanks!
Michael Barbee
12-01-2004 16:38:30
 Re: Re: Re: Unknown AC in the weeds in reply to Lee, 09-09-2003 18:50:03
I have a old house that has a allis chalmers squirrel cage and there is alot of ginding noise going on. I am trying to take it apart to see what it is. sounds like the ball bearings have worn out and are making the noise. Question:
How do I take it apart. It is a old motor and I'm afraid that I will tear it up. It is used for the cold air/heat exchange for the heat ducting. I undid the allen screws and tapped it with a hammer but it isn't budging. I don't want to wack on it and bend something... is there anyone that can help me.
Michael
JMS/MN
09-10-2003 10:35:02
If it has a blower on it, driven by a belt from the belt pulley, it is part of a mounted corn picker. Made for the WC, as well as the WD, WD45. Second version was the number 33 model, but similar to what was made for the WC. The picker was under slung, and took about a day to mount. Had to turn the rear wheels out, add brackets, snouts, elevator, etc. Easy to get stuck in wet fields with the low clearance. I imagine it could mount on the RC,since the frame is of a WC, but I've never seen one. RC would never have enough power for it anyway, with the C engine. Reason why they made it for only three years.
Sid
09-09-2003 19:40:46
If that were on a WD I would say they are part of a mounted cornpicker. I think Allis made a mounted picker for a WC but am not sure.
