Hydraulic RAM for my 1951 AC WD
Brian-Dexter
09-09-2003 08:57:02
The RAM I have leaks anytime the hydraulics are used. It leaks from around the one threaded joint towards the middle of the tractor. Is there a way I can fix this or does anyone know were I could get a new one? I have contacted some tractor salvage yards and no luck.
Brian
steve
09-09-2003 20:31:57
 Re: Hydraulic RAM for my 1951 AC WD in reply to Brian-Dexter, 09-09-2003 08:57:02
Brian, i am not sure what we are talkinga bout exactly, but the cylinders have a hose fitting on the back that is threaded, it can be removed and thread tape installed if needed. the cylinder rod stickes out the other end. there is porbably a threaded nut around the shaft that is holding the pakcing into the stuffing box. this may have a knurled ring or a hex nut. you can tighten the big nut with a pipe wrench and tighten the packing a turn or so and see if that helps. if im on the wrong topic, sorry.
