AC , 1950 Model C
Rich
09-08-2003 09:59:04
I bought this tractor from the original owner. It was always well cared for but has not been restored. It starts easily enough but then warms up and shuts off. When I try to restart it it is hard to crank and has a squeeking sound which I have not been able to locate the origin. It will not start this way. After it cools there is no squeeking sound and will start. Please advise.
Bryan Smith
09-10-2003 12:28:34
 Re: AC , 1950 Model C in reply to Rich, 09-08-2003 09:59:04
Wonder if (a) it needs a valve job - heating the valves makes them fit worse and results in poor compression, (b) oil pressure is low and the mains or rods are trying to sieze up on the crank, (c)main or rod bearings are worn? Something is heating up and either binding to shut you down or perhaps expanding to allow air flow in (like at the manifold) and leaning out your fuel mix to shut you down. Could be coil too. Does it sound like it's laboring hard when it shuts down? Or does it just shut off?
Rich
09-08-2003 11:26:28
