PTO problem - help
Ken Hubbard
09-05-2003 13:36:29
I have a 1936 B with a one inch or 7/8 PTO shaft. My bush hog shaft is the same diameter. I need to replace the drive shaft that goes from the tractor to the hog but "Tractor Supply" said they don't carry that small a size.
Anyone know where I can go?
Thanks for the help.
Ken
Ken Hubbard
09-07-2003 14:50:03
 Re: PTO problem - help in reply to Ken Hubbard, 09-05-2003 13:36:29
My mistake. It is a 1938 B tractor. I tried the adaptor idea and it made the shaft too long. It barely cleared the bars and ended up busting the u-joint. I'll need a shaft that has a 1 1/8 diameter on both ends.
Will the transmission shops still help me with this?
Ken
Thanks for the help Rod and Dan.
Rod (NH)
09-05-2003 16:11:08
Hi Ken,
As far as I know no Bs were made in 1936. The early B PTOs had 1-1/8" dia - 6 spline shafts. The later versions used the more modern 1-3/8" dia - 6 spline shafts. You should try a local power transmission supplier for assistance in putting something custom together for you. A 1" dia - 6 spline shaft is common but not in conventional PTO applications. Check your yellow pages under "power transmission" and take whatever mating pieces you have with you for positive identification.
third party image Rod
DanD.
09-05-2003 16:07:34
If you need a larger diameter PTO shaft, you can get an adapter that goes on the small PTO shaft on the tractor to make it larger. THese are available at any farm supply store. Local store here has them on the shelf. Also, model B was not built until 1938. THere is a serial number page here on this site that will tell you the year of your tractor if you have the serial number.
