D-17
IHGUY
09-04-2003 17:38:05
I am an IH man, but had to jump over to the orange page for some info on a buddies D-17. It is an early D-17, not a series II. I was wondering what the Hi/Lo lever does? Is It like the T/A on a Super MTA? Or is it a speed range selector? I need to do some plowing in some heavy clay and would like to know. Also, will it be able to handle 2-14's? It is a narrow front, will it need front weight? Thanks for your time
Wally G.
09-07-2003 17:46:39
 Re: D-17 in reply to IHGUY, 09-04-2003 17:38:05
Hey IH Man, We use to pull a 3/16 slat plow with the d17 gas n/f and 4/14 plow with the d17 diesel and run away from the 400 Farmall with 3/14s. Tell your friend he has a really good little tractor there.
Tom
09-05-2003 00:30:14
IHGUY, you are lucky to get to run a D-17 - great tractor. The long shifter on the right side is called "power director" as stated below. Netural is in the middle, low is back and high if forward. You can start and stop the tractor with this handle. It does not hurt to slip it under heavy loads to start the tractor up with plow in the ground, heavy hay windrow, etc. Don't use the foot clutch when using the power director. You can change from low to high or high to low on the power director with the tractor in motion, under load, without touching the foot clutch. This is the BEST feature of the old ACs.
CHALMERSBOB
09-04-2003 20:01:33
THE LEVER ON THE SIDE IS A POWER DIRECTOR, HAS HIGH & LOW RANGE IN ANY GEAR WITH NEUTRAL IN THE MIDDLE. ALLOWS YOU TO UP SHIFT AND DOWN SHIFT WITHOPUT USING THE CLUTCH AND GIVES YOU LIVE PTO BY SHIFTING INTO THE NEU. POSITION.
D17 WILL PULL 4 14" PLOWS WITH NO PROBLEM. LIKE HAVING 2 IH M'S. DON'T USE THE D17 TOO LONG OR YOU WILL WANT TO CHANGE FROM RED TO ORANGE. AND JOIN THE REST OF US.
GOOD LUCK
BOB
