Bought a WD45 and the Hydraulic arms don't work? h
dave
09-04-2003 16:39:33
I just bought the tractor and it was low on hydraulic fluid.. I added fluid and they do not move. The are are in the down position but I cannot manually lift them. They act as if they are froze tight?? I know on my WD I can lift them up with no trouble.
Any suggestion as to what could be wrong? Appreciate your responses.
thanks
Dave
Graber
09-06-2003 15:27:04
 Re: Bought a WD45 and the Hydraulic arms don't wor in reply to dave, 09-04-2003 16:39:33
Try turning the adjusting screw in front of the pump down between the side rails.If it is turned way back toward the pump it won't lift. Mine was to far the other way and kept trying to lift after it was all the way up.
JMS/MN
09-04-2003 20:20:24
Disconnect a hose to a cylinder, or hook up an extra hose and cylinder to the third port on the pump. See if you have pressure.
dave
09-04-2003 20:30:26
 Re: Re: Bought a WD45 and the Hydraulic arms don't in reply to JMS/MN, 09-04-2003 20:20:24
will do.
thanks
