WD won't run
Jim-IL
09-03-2003 19:20:05
My WD starts and runs for maybe a minute and kills. It'll restart and do the same thing, run a minute or so, and then kill. I assume this to be a fuel problem, so what's the best course of action?
steve
09-04-2003 19:18:09
 Re: WD won't run in reply to Jim-IL, 09-03-2003 19:20:05
you are runing out of gas. check the flow thru the gas tube into carb bowl. is it o.k? if not check the flow thru the sediment bowl to the carb. o.k? if not drain the gas tank and flush. does it fow out the bottom? if flow is o.k. to the carb, then you need to take the bowl off carb, clean it out and clean the jet, and make sure the inlet needle valve is not plugged with rust.
Glen in TX
09-04-2003 12:08:56
Could be fuel or electrical. Is it running the carb or sediment bowl dry? If so you probably have rust flakes to clean out of the tank and carb. A quick easy fix I have used is to flush the tank and put a short copper tube in top of the sediment bowl to keep the flakes out. This will work till you can take the tank off and fix it right. Could also be a sticking carb float or valve seat. A bad coil, bad switch, bad wiring, could all cause this. Just have to narrow it down.
