How did they do that?
DaveInMI
09-03-2003 05:29:43
There's a WD in the tractors for sale pictures that has been reversed. I've seen a few WCs done that way. Can the internals of the banjo housing be flipped on the WD?
DaveInMI
09-04-2003 05:40:46
 Re: How did they do that? in reply to DaveInMI, 09-03-2003 05:29:43
Thanks folks. I'm tempted to try it.
JMS/MN
09-03-2003 23:27:23
Yes- it is very simple- easier than on a WC, because it requires no grinding of the casting. Just pull the axles out, remove the ring gear, and rebolt it after flipping it over. Did mine in '78-'79. Provides great traction with weight on the rear axle instead of the front.
w
09-03-2003 18:22:16
yes, you can place the ring gear on the other side of the pinion gear, reverseing everything.
09-03-2003 10:03:46
third party image
old fart
09-04-2003 00:07:35
 Re: Re: How did they do that? in reply to Picture, 09-03-2003 10:03:46
is this possible on a farmall,or allis only.Thanks and have a great day.
RayP(MI)
09-04-2003 19:07:32
 Re: Re: Re: How did they do that? in reply to old fart, 09-04-2003 00:07:35
When I was in college in the late '60s I worked summers at a pickle factory. We had a couple Farmall yard tractors converted to rear mounted fork-lifts. Drive was reversed, so apparently they can be! Thesse were probably C or Super C tractors, but it's been a long time, so don't hold me to that! They were pretty good tractors, so the conversion must have been pretty well conceived, and done.
RJ-AZ
09-04-2003 17:13:28
This was a pretty common thing to do in cotton country where AC. JD and IH Tractors were put under cotton pickers. Some used adapters on the axles and extended forks for a single tricycle steering tire.
