WD-45 fuel gauge
Jim McDonald
09-02-2003 18:44:00
I have taken the fuel tank off my tractor to clean it. The fuel gauge is original and wasn`t working. I found the old float half off the bar and soaked through with gas. Can I get a new float or what else could I use as the float.
thanks, jim
Sid
09-03-2003 17:48:48
 Re: WD-45 fuel gauge in reply to Jim McDonald, 09-02-2003 18:44:00
Jim I can understand why you and smitty who posted below would want to find what you are looking. I talked to a couple of parts people today and found one who had no idea what I was talking about one who did but said it was no use one who went to the trouble to look it up. He said it was not listed as an AC part but said he remembered selling them and said he would look back and talk to some of the oldtimers he knew and see what he could find out. He said I would here from him in a couple of days if there was any thing he could do to help.
acorange
09-03-2003 15:29:02
Yeah, what dave and JMS said. Get a wood strip or dowell, put a hole in it and thread a strip of leather thru it so it can be hung on a nail.
Drive a nail into your barn wall by the door that you drive your tractor thru and hang up your fuel guage. Then mark on the wall "official AC fuel guage" by your nail so that no one will use your stick for anything else.
Dave K (Fl)
09-03-2003 14:30:00
Take a wooden stick, fill the tank full and mark F on the stick with a magic marker. Measure the stick 3/4, 1/2 and 1/4 and mark them. Keep stick in tool box. Has worked over 50 years for me.
Dave
09-03-2003 05:04:17
Sounds like a D-17
Jim McDonald
09-03-2003 18:56:02
 Re: Re: WD-45 fuel gauge in reply to ???????, 09-03-2003 05:04:17
You are very good and very close. I went the thirty miles to the dealer who used to carry AC and still gets parts. He took one look at the fuel gauge mechanism and said my tractor was either a D-14,15,or 17. He told where to find the numbers on the tractor and sure enough its a D-14. He could not get the float alone I would have to buy the whole mechanism. I came home and put a large cork on the rod for a float and filled it with gas, it works. I am not throwing my stick away just yet. I am a rooky at this and I really appreciate the help. thanks, jim
Sid
09-03-2003 00:15:44
There is a fuel gauge that was built into the gas cap on some of the WD45s. I remember seeing them on a couple of new tractors at the local dealer. I would try AGCO dealer I am pretty sure this was an AC item.
Smitty
09-03-2003 06:28:34
 Re: Re: WD-45 fuel gauge in reply to Sid, 09-03-2003 00:15:44
My WD, which came into the family some 30+ years ago, had a guage built into the fuel cap. It's a cork float on a lever mechanism which raises and lowers a disc inside a glass tube atop the fuel cap. On the chrome top plate that covers the tube, it is engraved McKew Mfg. Co. Inc., Fort Wayne, IN, USA.
According to my research, this is not a factory AC item, dealer says no go. I've checked with several Hit-n-Miss engine suppliers, and nobody has ever heard of such a company. I'm in need of a replacement glass tube, measures 1.125" OD by 2.25" in length. If anybody has any ideas on where to look for such a piece, I'd sure appreciate the info. If anybody else has info on this company or this "fuel cap with a guage", please post.
Thanks.
Good Day
Jake
09-03-2003 20:37:54
 Re: Re: Re: WD-45 fuel gauge in reply to Smitty, 09-03-2003 06:28:34
Glass tubing is available. McMaster-Carr for one.
Something from a gas engine oiler might match.
Seems I saw glass tubing in a hardware store some years ago but I don't know what the application was for. Perhaps a boiler sight glass?
dean
09-03-2003 18:09:34
perhaps easiest thing to do for the tube is to find a test tube that dia and cut of the rounded end and then you would have the glass tube..might be able to find a plexiglass tube which would be tougher material
wolfy
09-03-2003 16:41:32
Some Internationals came with a filler-cap fuel guage. We have one on a 230 that still works. Not sure the AC & Int had the same size cap-pretty sure they are different size.
JMS/MN
09-02-2003 22:13:10
AC did not have a fuel guage- it was an aftermarket. We all used a wood stick.
Eldon
09-02-2003 18:59:48
As far as I know a fuel gauge wasn't offered on the WD45. Yours must be an aftermarket affair of some sort.
