Cat 2 tractor with Cat 1 Mower
Ryan(MO)
09-01-2003 21:07:46
Any comments on using a Cat 2 tarctor with Cat 1 hog? I have a AC 190XT, but a friend who owned it before used a Kingcutter 6' (Cat 1) and used bushings to convert it to fit Cat 2. He used this set up for over 10 years and never burned up a gear box. He ran the tractor at about 2,200. Should I cheat and run a cheaper hog also?
Aaron
09-02-2003 06:08:04
 Re: Cat 2 tractor with Cat 1 Mower in reply to Ryan(MO), 09-01-2003 21:07:46
I can't see where that would be a problem as long as your careful. My brushhog is set up with a 100hp gearbox rating, and a heavy duty slip clutch on the mower. If yours has shearpins instead of a slipclutch, just be sure to use the correct grade of bolts so they will in fact break before something on the machine does.
