Power steering for WD 45
Ross Oestreich
08-28-2003 14:00:16
Thanks to Ron I located a Char Lynn valve. Now I need a pump and other parts to install power steering. I even have the direction for installation. Who can help?
Dave Grubb
08-29-2003 14:28:39
 Re: Power steering for WD 45 in reply to Ross Oestreich, 08-28-2003 14:00:16
I installed a Char-Lynn unit on my WD45 and used a Saginaw automotive power steering pump that had been on a late 60s to early 70s Ford product. It has an integral reservoir and is a vane style pump. I relocated my alternator to above and a little to the right of the top of the engine. I used a length of large size sink stopper ball chain as plumb line from the alternator pulley down to the crankshaft pulley to locate the alternator for the most clearance of its drive belt and the governor arm. The belt runs close but is steady and does not rub the governor linkage arm. I mounted the power steering pump at the old generator mounting position. The installation requires a dual groove crankshaft pulley for best results and the least amount of strain on the water pump. I chose to have the forward crankshaft pulley groove only drive the fan/water pump. I'm using a 'B' size belt instead of the 'C' size like the original and everything works ok. The original after market kit from Char-Lynn used a Char-Lynn pump with an attached reservoir. These pumps are still available under the Eaton name. You can find them on E-bay auto for around $10-$35 and are a better pump than the Saginaw. They were used on a lot of 50s and very early 60s autos. The Eaton pump is a roller pump with a smaller pulley and somewhat larger output. The Saginaw pump is available as a rebuilt unit (around $75) that you can exchange and reuse the reservoir if you find one you like but needs overhauled. You have to have the pulley pulled off/pressed on though. The most important thing to look for in selecting a Saginaw unit is the direction the return hose tube connection is facing. They are pointed in lots of directions and you only want an aft and left facing short tube. I have been well pleased with my installation, but the pump can run low on volume if you try to spin the wheel too fast. Sorry for the long post.
Steve from MO
08-29-2003 08:24:36
If you want to take the easy way out, a power steering pump from a car/light truck will work nicely. Swap out the pulley on the pump for a smaller one so you get enough output at tractor RPM's, and route the hoses so they don't get hung up on anything that moves. GM even made a generator in the 60's with a pump on the back end so you could use your original brackets with some spacers.
