AC engine in an Onan generator, need parts
Rachel
08-28-2003 09:17:36
Hi, we have an AC engine, and in-line 6 diesel, in an Onan generator and we need parts, i'm having trouble locating them. We need a water pump, fan and wire guard. Any suggestions on where I can go? We are in the greater Cincinnati area.
Thanks!
DanD.
08-28-2003 10:51:08
 Re: AC engine in an Onan generator, need parts in reply to Rachel, 08-28-2003 09:17:36
What is the engine model number? SHould be on a metal tag on the left side of engine. Is probably the same as on tractors with the same engine. THen you could order from AGCO, get aftermarket from many sources, even go to a tractor salvage yard.
jeff van linge
11-03-2003 13:01:39
 Re: Re: AC engine in an Onan generator, need parts in reply to DanD., 08-28-2003 10:51:08
I work for the Cummins/Onan Distributor for the State of Ohio, Cummins Bridgeway,LLC. We have a branch located in West Chester, OH. Our parts department should be able to help you, as we work on these units all the time. Our branch # is 513-563-6670.
