Difference between WD and WD-45
Jim F.
08-27-2003 12:05:50
Okay, take it easy on me here. Regular John Deere guy who has been toying with Olivers the past year and suddenly have an interest in Allis after tuning one on our dyno for a good friend of ours.
Title says it all, what is the difference. Thanks in advance guys!
Jim F.
Chicora, PA
Harmon Moody
09-10-2003 19:02:18
 Re: Difference between WD and WD-45 in reply to Jim F., 08-27-2003 12:05:50
Engine wise the rods are 1/2 inch longer giving it a higher compression.
Dave K
08-31-2003 13:21:03
We had both on the farm and could not tell much difference in day to day work.
Dave
Ian Schedler
08-29-2003 17:40:03
45 had 45 hp at the Rear PTO and the Wd only had about 38 but they both are very good pullers in a low gear and you will never run out of power with either of them and the 45 you could get in a disel engine.
kevin
09-08-2003 19:14:02
 Re: Re: Difference between WD and WD-45 in reply to Ian Schedler, 08-29-2003 17:40:03
wd45 have gas engines not diesel and they both have 38hp at the pto the wd45 offers fatory wide front and the wd doesn't
John (C-IL)
08-27-2003 12:17:52
engine on the WD is 201CI, 45 is 226 CI. 45's and late WD's have the curved shifter with the helicut gears. Later 45's have a 3 plate hand clutch. Many other smaller differences.
dave spronk
09-30-2003 11:33:58
 Re: Re: Difference between WD and WD-45 in reply to John (C-IL), 08-27-2003 12:17:52
wd's had a 201 cu. in. engine 4" bore 4" stroke, wd45's 4"bore 4.5" stroke 226 cu. in. gas also available was a 45 diesel 6cylinder 230 cu. in.
