Company Logo (800) 853-2651 Shop Now
WD 45
Mike
08-26-2003 05:23:59
I recently purchased a WD45 from my neighbor. He had owned it for 28 years and all he did with it is move snow. So when I got it I thought I would be smart and change all of the fluids, everything went fine until changed the engine oil. I changed the oil and filter and srarted it up and watched the oil pressure guage for it to come up, after about 20 seconds it come up maybe an 1\8 of an inch where before I changed it it come a good half inch. Am I missing something or did I end up with a lemon?
Aaron
08-26-2003 11:59:16
 Re: WD 45 in reply to Mike, 08-26-2003 05:23:59
I bet it is not an Allis Chalmers (Agco)oil filter. They are very touchy, and will only carry correct oil pressure with an AC filter. Hope this will help you.
Rod (NH)
08-26-2003 07:19:10
Hi Mike,
You might find this link about my own experience on my '42B informative.
third party image Rod
CWL
08-27-2003 06:19:43
 Re: Re: WD 45 in reply to Rod (NH), 08-26-2003 07:19:10
Good info. Seems to answer my question below quite well.
Mike
08-26-2003 07:49:17
I have forwarded this to my supplier. He seemed interested in finding out why they didn't redesign them to increase the oil pressure. Thanks Rod for your help I thought that I may have something bad wrong with the old girl.
Dale(MS)
08-26-2003 05:33:54
Mike, Been some talk about oil filter makers making bad filters that do just what you described. DO NOT RUN this tractor until you get the right one. Agco's are right or Car Quest C-159(Fram).Dale
Steve in N.J.
08-26-2003 06:52:58
 Re: Re: WD 45 in reply to Dale(MS), 08-26-2003 05:33:54
Mike, Dale is correct with the oil filter problem. Seems the Wix & Napa filters (same filter if that's what you happen to use) have a new internal design which dropped the oil pressure drastically. Frams are okay so far, along with some of the other aftermarket filters that are available for that engine.
Steve/B&B Custom Circuits
CWL
08-27-2003 06:09:54
 Re: Re: Re: WD 45 in reply to Steve in N.J., 08-26-2003 06:52:58
Even Wix? I put a Wix filter on my WD last fall. I had no problems with it. It was a string type filter with a dowel rod shoved through the center to keep the hole open. Did I just luck out and get an old filter, or is there more than one Wix filter that will fit? My oil pressure is good even after working the tractor in 100 deg. heat for a couple of hours. I'm running 30wt oil.
Thomas S Hamilton
08-26-2003 21:23:27
I have been given a 1937 or 1938 Allis Chalmers WC. Is there a "WC"?
Also, I have convinced the organizers of the Dallas, Oregon Summerfest and car show to have a tractor show at the next year car show. Last weekend of July. Anyone interested?
mike rath
08-27-2003 04:44:49
 Re: Re: Re: Re: WD 45 in reply to Thomas S Hamilton, 08-26-2003 21:23:27
Yes they did make a WC.
Mike
08-26-2003 07:36:52
It did happen to be a WIX filter that I had put on.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
Latest Ad: Need one ,castiron, screw-on hub cap. for a JI Case 8 foot grain drill [More Ads]
