'38 B, if the engine starts....
njs
08-26-2003 04:57:27
how do I stop it? No switch found, there is an unconnected wire off the magneto and a pc of spring steel close-by.
Thanks,
Jeff
Steve in N.J.
08-26-2003 09:06:45
 Re: '38 B, if the engine starts.... in reply to njs, 08-26-2003 04:57:27
njs,
We have a mag switch kit available if you intend to wire one in. Comes with the switch, which you install in the Ammeter box (if equipped) and the circuitry for the mag & fiberloom. Drop us a line if interested...
Steve/B&B Custom Circuits
Trevor
08-26-2003 16:57:22
 Re: Re: '38 B, if the engine starts.... in reply to Steve in N.J., 08-26-2003 09:06:45
Steve,
What circuitry? It just shorts to the frame doesn't it?
Steve in N.J.
08-27-2003 11:37:11
 Re: Re: Re: '38 B, if the engine starts.... in reply to Trevor , 08-26-2003 16:57:22
Trev,
One wire down the harness to the mag. The other to a good ground. Viola! Just enough to do the job....
Steve/B&B
njs
08-27-2003 05:03:53
Trevor,
That's my plan. I suppose there are those out there that would be needing the help from Steve.
Thanks anyway Steve.
njs
08-26-2003 07:39:41
Rod(NH) and Dick L.
Many thanks. I did not like the idea of getting off the tractor to do something that was not clear to me until now. I will wire in a switch that I can reach from the seat.Of course it will require me to get the engine running 1st! (Couple weeks away yet)
Thanks again.
Dick L
08-26-2003 07:32:31
inside of the magneto there is a wire that connects to the hot side of the points on one end and connects to the inside of the stud that sticks out thru the magneto with a piece of flat spring steel to push on to short out the points and cause the engine to stop. A wire should run from the switch box mounted below the stearing wheel to that stud with the spring. The switch, when working properly, will short out the points in the same manor when connected to that stud.
Rod (NH)
08-26-2003 07:27:57
Hi njs,
The spring clip, if it's the one I am familiar with, needs to be depressed with your finger until it makes electrical contact with the housing in order to ground the magneto and stop the engine. If there is a wire connected to the same stud that the spring clip is attached to, just temporarily ground the wire to accomplish the same thing. For safety reasons, you should run a wire from that magneto stud to a switch that is operable from the tractor seat in order to do the grounding and stop the engine. My '42B was originally (from the factory) like what yours apparently is. You had to get off the seat, walk around the other side of the engine and depress that clip with your finger to stop the engine. That's a saftey hazard that you should correct right away.
third party image Rod
