G exhaust manifold
Chuck
08-25-2003 20:34:22
I have been doing some work on my neighbors Allis G. We found a small hole in the top of the exhaust manifold near the #3 piston counting from the back of the tractor (front of the engine?) Is this a common problem in the casting or did he just get a weak casting? I was thinking of trying to plug it with some kind of high temperature sealant rather than trying to get it off the block. Any suggestions? It's a working tractor rather than a showpiece.
Thanks
Dick L
08-26-2003 07:24:59
 Re: G exhaust manifold in reply to Chuck, 08-25-2003 20:34:22
It can be welded up if not real thin all over. Tap around on the other end with a chipping hammer, you will probably find it should be welded at the same time. I would torch weld it with brass or cast iron rather than nickle. You can use an old piston ring if you can not find cast iron rod. Use plenty of flux with a fine pointed flame on the torch for cast iron.
