AC 180 Crank
Ossie Smith
08-25-2003 19:04:22
does the end gear come off of a crank on a 180 AC diesel engine??? Got to take the crank out to have it turned and do not plan on disturbing the rest of the engine. Can the gear be pulled or is it a part of the crank???
Thank in advance
Farmer Gene (WI)
08-26-2003 07:34:47
 Re: AC 180 Crank in reply to Ossie Smith, 08-25-2003 19:04:22
Any that I've sent in to have reground I've left the gear on, never seemed to be a problem, at least they never said anything about it. You could ask them if it is necessary to have it removed for them to grind it.
Jr64
08-25-2003 20:37:13
You can pull the gear off with a puller. You may have to heat the gear a bit to get it off. You'll have to heat the gear in oil to reinstall it and it'll slide right on the crank.
