AC- c with woods belly mower( belt pattern)
RICHARD
08-24-2003 17:02:17
I AM IN NEED OF THE BELT DIAGRAM FOR MY ALLIS CHALMERS C. WHAT IS QUICK FIX FOR LEAKY HYDROLIC CYLINDER MOUNTED TO DECK OF MOWER. THE PACKING IS GOING TO GET REPLACED OR FELT REPLACED, ONLY SOLUTION.
craig
08-28-2003 10:37:34
 Re: AC- c with woods belly mower( belt pattern) in reply to RICHARD, 08-24-2003 17:02:17
Try sending a message to the Woods company. They sent me a set of pictures showing the proper belt pattern as well as the instructions on how to properly adjust the belt. They can be reached at www.woodsonline.com/
You may want to try and tighten the packing nut on that cylinder before replacing the packing. That chevron style of packing needs to be kept fairly tight to keep from leaking given the low volume-high pressure cylinders that the C uses.
Good luck
