Allis- Chalmers G Sleeved???
Scott M
08-23-2003 09:48:17
Does the engine in a G Allis have sleeves?
Glen in TX
08-27-2003 23:26:40
 Re: Allis- Chalmers G Sleeved??? in reply to Scott M, 08-23-2003 09:48:17
You should have a Continental N62, 62C.I. if you have the small throat carburetor. Same engine as in a M-H Pony. Can someone explain why some of the G's used a different carburetor? Did they have a different engine as well?
AWB
08-23-2003 14:56:48
No. They did not come from the factory with sleeves.
Don LC
08-24-2003 21:02:37
 Re: Re: Allis- Chalmers G Sleeved??? in reply to AWB, 08-23-2003 14:56:48
You can get all your engine parts at NAPA
Scott
08-24-2003 09:33:26
Then I guess it would be pretty expensive to rebuild it?
Dick L
08-24-2003 15:19:53
 Re: Re: Re: Allis- Chalmers G Sleeved??? in reply to Scott, 08-24-2003 09:33:26
I had NAPA Bake, Clean and wash my G block and head. They also bored it out .030, put in new valves with guides, ground the valves and seats, and ground the crank shaft. They also resurfaced the head and I bought the pistons, rings, wristpins, and matched bearings. It came to 1100.00 and I put it back togather.
AZ Jack
08-23-2003 21:21:41
AWB is correct-the G has a Continental engine, not an Allis built engine.
