WD-45 ser #, and pto seal
Scott Ashburn,
08-23-2003 06:12:19
Just bought a WD-45, and in the process of repairs that were needed. am looking for the serial number to ident. year, anyone know where it is? Also, the pto seal needs replaced, It is a double lip seal, outer piece is felt, I assume its a dust shield, inner is lip seal. Parts store can't match it up, only get a single lip seal for it. Will this be ok with a new wear sleeve, or should I insist on the double lip, and continue looking. if so, anyone know where I can find the seal? I live near Kansas City, thanks, Scott, MO.
david
08-25-2003 10:02:37
 Re: WD-45 ser #, and pto seal in reply to Scott Ashburn, MO, 08-23-2003 06:12:19
Found my serial # looking from rear of tractor on left side of differntial housing between brake access cover and operators platform
Brian G. NY
08-23-2003 16:35:07
The PTO output shaft seal you need is: National #6241S. The serial number is located on the left vertical surface of the differential/brake housing. Look for a smooth surface between the brake spring hole and the brake adjusting bolt/locknut. The number is stamped there (sometimes faintly) and will begin with the letters WD.
Scott A, MO
08-24-2003 06:39:58
 Re: Re: WD-45 ser #, and pto seal in reply to Brian G. NY, 08-23-2003 16:35:07
the 6241S is a single lip seal, I hopefully have found the correct double lip seal, with a speedy sleeve. Have it on order, will be here monday. If it's right, I'll post the part #. Thanks.
Tom IN
09-17-2003 20:33:43
 Re: Re: Re: WD-45 ser #, and pto seal in reply to Scott A, MO, 08-24-2003 06:39:58
Were you ever able to purchase the correct double lip seal for your PTO? I too am in search of this part number. Any info would be appreciated. Thanks in advance.
