AC B clutch
Henk
08-22-2003 19:12:46
I recently purchased a AC B it runs great only when driving and pressing the clutch it does not disengage ride away what can be the problem and how to fix it.
Dale(MS)
08-23-2003 06:23:14
 Re: AC B clutch in reply to Henk, 08-22-2003 19:12:46
Henk, Sometimes the crankshaft wick that lubricates the pilot bushing on the flywheel allows oil to get all over the clutch mechanism. Dust, oil, and time will make for some pretty serious crude to bill up in that area. Might get a couple of cans of brake clean or electric motor cleaner, remove the starter and spray clean that area real good. Just something simple to try first. Dale
steve
08-23-2003 07:00:09
 Re: Re: AC B clutch in reply to Dale(MS), 08-23-2003 06:23:14
I agree with Dale. probably oil stuck to the plate. a simple solution i have used is pull the starter and spray 2 gallons of water/ dishwasher fluid or liquid soap on the clutch and plate. rotate the motor 1/4 turn and keep going. you cant used too much. have someone hold in the clutch while you spray so it gets all over. there is a 2 inch hole inthe bottom that everything runs out. make sure it is open. poke a screw driver in the hole and wallow it out. spray in out after 15 minutes with the garden hose. it took 40 years to buildup. you might have to do it again in 10 years.
steve
08-23-2003 06:58:58
I agree with Dale. probably oil stuck to the plate. a simple solution i have used is pull the starter and spray 2 gallons of water/ dishwasher fluid or liquid soap on the clutch and plate. rotate the motor 1/4 turn and keep going. you cant used too much. have someone hold in the clutch while you spray so it gets all over. there is a 2 inch hole inthe bottom that everything runs out. make sure it is open. poke a screw driver in the hole and wallow it out. it took 40 years to buildup. you might have to do it again in 10 years.
Henk
08-27-2003 16:10:57
 Re: Re: Re: AC B clutch in reply to steve, 08-23-2003 06:58:58
Thanks for the input I have tried to spray it out with 150 psi but it still doesn't work I was going to split the tractor but first I will try the soap trick and the one thing that I didn't do and that was to keep the clutch pressed in
thanks for the info .
