WC Battery Ground
Sam Hamilton
08-21-2003 16:42:46
Is the battery on a 1939 WC Allis negative grounded or positive grounded? Other than the polarity of the generator and reversing the wiring on the ammeter, does grounding make any difference? Thanks.....Sam
steve
08-21-2003 18:48:48
 Re: WC Battery Ground in reply to Sam Hamilton, 08-21-2003 16:42:46
tractor was originally 6 volt positive ground. you are correct, you can reverse and have negative ground if you change the generator polarity and amp gauge wire. the starter will not know the difference. you can also install a 12 volt battery if desired, and new generator. again, the starter dont care, but will spin faster.
