WD45 will not start
Kent
08-20-2003 11:41:39
WD45 was running fine, then while cutting while cutting 12-16" grass with a 5' king kutter it started to intermittently cut out (like it was not getting gas). Finished cutting but the next few occasions it was very difficult to start and did not want to run well. I have since begun attempting to solve the problem: Cleaned the carb with carb cleaner, cleaned the air breather, gapped and replaced spark plugs, replaced badly worn points.
Now it will not start; Getting gas but no spark. Cap and rotor appear good.
Coil ???? Have purchased a new one but am reluctant to install as it was about $50.00.
Any way to test the coil or any other ideas would be greatly appriciated.
Thanks
Jim B
08-20-2003 13:55:14
 Re: WD45 will not start in reply to Kent, 08-20-2003 11:41:39
Kent/ I had a simmular problem with my tractor. the problem was a bad key switch. Losing contact and not sending power to the coil. try bipassing the switch>
Kent
08-20-2003 17:38:20
 Re: Re: WD45 will not start in reply to Jim B, 08-20-2003 13:55:14
Jim, Thanks for the help. I took your suggestion and bipassed the switch, it still did not work so I changed the coil and it started right up. Now runs very smooth.
Thanks again,
Kent
Ronnie
08-22-2003 10:16:21
 Re: Re: Re: WD45 will not start in reply to Kent, 08-20-2003 17:38:20
Kent, My WD-45 had a similar problem, but I got a coil from AutoZone for under ten dollars. I think it was for about a '48 Ford. It works fine.
