WD-45 Snow prep
JS in IL
08-19-2003 17:19:25
Hello all, I have spent the last three winters fighting snow with my wd45 and while it gets the job done, it takes forever. I have about a 1/4 mile drive that will drift if you even mention the word snow within earshot. I have pretty much completed my "Restification" on the ol 45 and it is ready for use. I also have a 6' snow blower and a 7' blade to remove all the offending drifts. What do I need to do to in terms of weights/chains etc to spend more time plowing the lane instead of spinning the tires and making small piles all over. Right now, a bite of snow, and the tractor starts spinning and stops plowing. The snowblower is actually worse, back it into a drift and it will spin instantly. I have no lack of power (obviously) but no weights on the rear, nor do I have any fluid in the tires, and I am running 16.9x26's with I guess about 60 hp spinning them. Sooooo oooo, what would be the hot setup to put the power to the ground instead of snow roostertails.
Thanks in Advance
JS
JS in IL
08-21-2003 13:47:14
 Re: WD-45 Snow prep in reply to JS in IL, 08-19-2003 17:19:25
Well, thanks for all the info. Looks like I need to get some chains for the orange monster. I am fabbing up a weight box in front to add a few lbs. for the front. I also will add a couple side brackets to hold some suitcase weights on just in front of the rear axle. I really dont like the idea of fluid in the tires because that's what rotted the original rims in the first place. In fact, this was a dead tractor to begin with. I simply replaced all the broken stuff and upgraded everything I could with better technology for more reliability, and I think I have done it. Except for the snow it will simply not quit. Starts very easy in 0 degree weather, and will pull an unreal amount of weight all day long with just a little throttle. My restored WF PS wd45 6 volt wont even come close, in any way, to the power or dependability.
CHALMERSBOB
08-20-2003 19:37:59
SEEMS TO ME YOU TOOK A WELL BALANCED HP TO WEIGHT RATIO TRACTOR ANY TURNED INTO AN OVER POWERED MACHINE. THEN ADDED 16.9 TIRES TO MAKE MATTERS WORSE. YOU'LL NEED LOTS OF WEIGHT TO TAME THAT MONSTER. BETTER PUT WHEELIE BARS OR IT TO KEEP THE FRONT DOWN.LOL
donm
08-20-2003 12:59:28
The trax will make an awesome snow tractor, but only in the forward direction. In reverse the tires will spin inside the trax and you wont get anywhere. I have arps steel trax on a WD, could get for you a photo of the idler assys if you would like.
JS in IL
08-20-2003 15:35:54
 Re: Re: WD-45 Snow prep in reply to donm, 08-20-2003 12:59:28
The arps tracks only work going forward? Jeez, I was hoping they would make the tractor better both directions. I guess it would work with the blade though. Yes, Pictures would be great. I need pictures of the brackets that physically bolt onto the axle housing. I have everything else. I just need to see how the plates allow the springs and long arms to bolt to the tractor. Measurements along with pics would be even better. Any help is greatly appreciated.
Aaron
08-20-2003 06:30:19
As other have said, get yourself a good pair of tire chains. They make a world of difference. Here in Minnesota, I put them on my 170 AC and clear snow and feed cattle all winter with no trouble. You can also put fluid in the rear wheels which helps some, but if a leak develops it will rust out your rim very quickly. I personally would just put chains on the tires. It doesn't matter how much weight is on the rear tires if your on ice. They will spin out if you don't have chains. Hope this helps, Aaron
JMS/MN
08-20-2003 01:08:10
Frankly, I can't imagine any snow problem in Illinois that can't be handled with a WD45 with fluid in the tires and chains on them. The tractor should have about 40+ pto hp, and 14.9 x28 tires- certainly enough to handle the load.
Sid
08-19-2003 23:45:02
This idea does not require much in the way of money if it works. Mount the rear tire backwards and hold the snow blower up off the ground just enough for the extra weight. What did you do to get 60 hp? If you have the narrow front turning the front wheels inside out will help steering in mud and snow.
JS in IL
08-20-2003 15:31:15
 Re: Re: WD-45 Snow prep in reply to Sid, 08-19-2003 23:45:02
well, long story, but the short list ;looks like this, started with a Gleaner E block, added a 4 3/4 stroke crank with wd pistons to bump the compression up. then spent about a week with a die grinder smoothing out the head ports. tweak the gov. with gleaner springs (snappier). Use a 170 carb might have to make an adapter to fit the manifold, add some lightweight springs for the advance curve in the dist. HI-PO mopar performance springs work very nice. add an msd 6a box with pertronics elec. ignition. fatter plug wires sparkin autolites gapped to .045. add premium fuel and open the fuel feedline up to give it more fuel, I left the gleaner fuel pump on the motor to help the gravity setup. Ditch the oil can air cleaner for a dry cone filter on a lightweight tube either poking thru the stock hole in the hood, or right off the carb if you avoid the manifold heat. speaking of heat, ditch the stock fan and run an electric unit for no drag. I also run a 3 1/2" chrome straight pipe instead of the muffler. All of this makes a super reliable package that doesnt overheat, works all day, starts in any temp on the first spin of the starter, no plug fouling, no points setting. About the only maintanance is fluid changes, and valve lash adjustments, with a new air cleaner every 6 months.
The Combine also donated the 16.9x26 tires and rims.
Rock_Picker
08-19-2003 20:30:29
I dont know how much effect wheel weights will have, but a set of good chains will make a world of difference in your traction. My WD also spins & gets stuck in snowquite easily. A narrow front tractor also gets stuck easier. FWIW..... ..RP
JS in IL
08-19-2003 17:53:58
I forgot, I do have a big ol set of ARPS tracks ,24" steel jobs, complete except no brackets to mount them on the tractor. I was tniking that they would solve the weight/traction issues. If anybody has brackets or knows what they look like so I could fab something up I would appreciate it. I have the manual for them so all the adjustments/installation will be no prob, but installation depends on the brackets, and they "Vary from application to application"
Brian G. NY
08-20-2003 17:09:18
 Re: Re: WD-45 Snow prep in reply to JS in IL, 08-19-2003 17:53:58
I have a WD with a 6' bucket, a 6' A-C back blade, weights, chains and CaCL loaded tires. I don't have any problem removing snow but I'm lucky as my 1,000' steep driveway is situated so it's rarely effected by drifting. After a winter of watching my new neighbor whose driveway is N/S on an open field, my advice is this; Invest in snowfence and a row of sturdy hedge or evergreens. Do as much as you can to keep the snow from winding up in your driveway. Always move the snow to the lee side of your driveway to keep the drifts as low as possible. Having the equipment to remove snow is great but doing it every hour during windy winter days gets old mighty quick!! The older I get, the less I like movin' that damned white stuff. An Ol' Geezer from upstate NY.
