WD auxillary hyd tank?
Kent
08-19-2003 08:27:31
I have a WD and now putting on a AC loader that is made by Freeman. Right now it has a trip bucket and I will later add bucket control. Do you think the WD has enough fluid to cycle the lift which only has lift and not down pressure? I thought of adding a small tank plumbed into the drain hole and mount where it would gravity flow. Any ideas?? Thanks Kent
Brutus
08-19-2003 20:05:45
 Re: WD auxillary hyd tank? in reply to Kent, 08-19-2003 08:27:31
it should work,however,a story for your consideration. 25 years ago i put two small aux. tanks on the frame thinking i could run a dump wagon hoist. oil came back in so fast it blew a seal between trans. and clutch housing. not that yours would do that, but the old girls were built for a certain purpose.
-brutus-
mark/indiana
08-19-2003 16:18:36
You should be alright..mine is the same setup....but, I have considered a tank on the side of the frame to reduce heat...but if you run straight 30 wt diesel oil it will handle that heat problem better,,Mark
