wd45 Horsepower
Dennis
08-19-2003 07:43:18
Can someone tell me what a wd45 should produce at the pto shaft. My tractor was just tested at the local dealer and only turned out 30 H.P. Thanks, Dennis
kevin
09-08-2003 19:52:47
 Re: wd45 Horsepower in reply to Dennis, 08-19-2003 07:43:18
most wd45 pull about 38 hp if you get more concider you self lucky, if less your ignition system could be weak
Dennis
09-09-2003 17:47:13
 Re: Re: wd45 Horsepower in reply to kevin, 09-08-2003 19:52:47
I just compression checked my WD45 and it showed 145 lbs per cylinder. It has a rebuilt motor with high compression pistons. The head has also been completely redone. I am thinking maybe it could be carburetion or electrical or maybe both. I am only guessing though. I recently converted to 12 volt and electronic ignition. It starts easier and seems to run smoother, but where did the power go? Any thoughts would be appreciated. Dennis
kevin
09-08-2003 19:50:28
most wd45 will pull 38 hp if you have more you should concider yourself lucky if less your ignition system might be weak.
Max(ia)
08-19-2003 12:18:36
Should be close to 45hp if in top shape
