Leaking wc
Chuck M
04-04-1999 07:43:07
I have a WC that leaks when I have anti-freeze in the engine. When I have water in it, it don't. It is internal and gets the oil milky. Is there a patch for this with out taking it apart? Cause it runs real nice.
Brian
04-08-1999 17:35:22
 Re: leaking wc in reply to Chuck M, 04-04-1999 07:43:07
I have seen "block sealer" at cheaper auto parts stores. Cheaper Chuck's in Des Moines in this case. The stuff is supposed to seal cracks and blown head gaskets. I had a pickup that I was going to try it on, even bought a can of the stuff, but I decided to fix it right and pulled the head. I hear those engines crack between the main bearing ribs down below. If it was mine I might try the pour-ins first, can't hurt. Just get the antifreeze out of the crankcase as it will desolve bearings. Brian
