operating a semi-mount plow
New Farmer
08-17-2003 12:49:00
I just got an old AC7000 and wanted to try my hand at running a plow on it. What is the proper adjustment of the lift arms to keep the plow from digging in too deep? It is correct to drop the lift arms all the way first then drop the rear hydraulic cylinder all the way so the gage wheel keeps the rear at the right depth, then make minor adjustments with the traction booster lever?
JMS/MN
08-17-2003 22:19:22
 Re: operating a semi-mount plow in reply to New Farmer, 08-17-2003 12:49:00
The OPERATOR manual should explain proper operation of the hydraulic system, and correct settings for mounted and pull-type equipment. Normally the lift lever is used to raise and lower the plow, then the rear cylinder is activated with the remote valve. The Traction Booster lever is set once for proper operation and left that way- it is not adjusted with each round in the field.
