WD 45 Fan not turning
Vic Lovejoy
08-17-2003 05:49:21
I have been working on my WD45 for a coolant leak at the hose from the water pump, so I have the hood off. I noticed when I started it the other day that the fan wasn't turning - I waited for it to turn (is it a clutched fan somehow?) and the engine got very hot but the fan never turned. I pulled on the fan belt and was able to turn the fan and the alternator, etc. The pulley at the crank was turning freely. I pushed in on the hand crank and it caught, like the pulley can engage but wasn't engaged with the engine running.
The one thing I don't want to do is put the hood back on and run the engine, not knowing if the fan is running, water circulating, alternator charging, etc., and eventually blow its brains out.
Any advice/experience would be greatly appreciated.
vic
David
08-18-2003 19:35:23
 Re: WD 45 Fan not turning in reply to Vic Lovejoy, 08-17-2003 05:49:21
There is suposed to be a Woodruff Key under that Set screw.you have to slid the pulley off to get to it.
Aaron
08-17-2003 11:32:01
The pulley on the crank should NOT be able to turn with the engine off. It should have a pointed set screw threaded through it into the crankshaft. If the crank pulley is loose, I'd check for that set screw and make sure it's on right. It's not a clutched fan, if the engine is running, then the fan ( which is driven off the same pulley as the water pump) will turn. No fan turning = no water pump turning = one hot engine.
Aaron
vic lovejoy
08-17-2003 18:42:35
 Re: Re: WD 45 Fan not turning in reply to Aaron, 08-17-2003 11:32:01
Aaron, you were correct! I went out and looked and sure enough, no bolt at all in the pulley. I have a parts tractor that had the bolt so I switched it, and the fan turns. Now I can go back to working on the leak.
Thank you very much for your help and insight. This is a great forum.
vic
