WD 45
Fat Farmer
08-16-2003 14:57:27
How many plows can a WD45 pull?
kevin
09-08-2003 20:01:24
 Re: WD 45 in reply to Fat Farmer, 08-16-2003 14:57:27
if you load the tires a gas wd45 will pull a 3 bottom plow pretty easy up and down hills
Tim
08-17-2003 15:07:20
Looking for rear end parts for a wd45. info would be appreciated.
Jr64
08-16-2003 20:11:11
A "45" will pull 3 bottoms in most any condition. I have a snap coupler three bottom on my diesel and it will pull it up and down the hills in third. I'm quite sure it will pull the same plow in gumbo in second. I imagine my gas burner will do the same.
Doug in OR
08-17-2003 09:54:49
 Re: Re: WD 45 in reply to Jr64, 08-16-2003 20:11:11
Yup - what Jr64 said. This is using a mounted plow, of course. With a trailer plow, you will not get the benefit of the Traction Booster.
acd17toy
08-16-2003 18:29:38
a lot depends on the type of soil the conditon of the tractor, wheather the ground is level or hilly. a 45 will handle a two bottom 16" plow on all most all types of soil and terrian. a mounted plow will work the best.
