D-15 bad three point
woody
08-13-2003 08:01:29
I have a D-15 1, and the three point will drop on its own with the tractor running. This is much worse if there is an implement attached. Thanks for any info.
Dale(MS)
08-14-2003 14:29:11
 Re: D-15 bad three point in reply to woody, 08-13-2003 08:01:29
Woody, Check and see if you have gained oil in the the transmission and lost fuild in the hydraulic compartment. If so your hydraulic hose may be busted inside the lift housing. Might also check the transport valve to see if it is turned in all the way. Just some easy things to check quick. Dale
woody
08-14-2003 18:50:41
 Re: Re: D-15 bad three point in reply to Dale(MS), 08-14-2003 14:29:11
This is not normal then? This tractor should be abe to hold a small brush hog in the full raise position? Where will I find the transport valve? Thanks, Woody
Dale (MS)
08-14-2003 20:02:53
 Re: Re: Re: D-15 bad three point in reply to woody, 08-14-2003 18:50:41
No Woody that is not normal. The transport valve is under the left side under the seat. What did the fluids look like? I suspect a busted hose. Dale
woody
08-15-2003 18:47:12
 Re: Re: Re: Re: D-15 bad three point in reply to Dale (MS), 08-14-2003 20:02:53
I have not checked the fluids yet. I plan to do that tomorrow. Thanks for the help.
